nVidia Grafik geht nicht
Ayron
Hallo!
An meinem M14x geht die nVidia-GPU nicht (GT555M, 3GB). Unter Windows sagt das Treiberinstallationsprogramm nur: "The graphics driver could not find compatible hardware".
Linux ist hier schon etwas detailierter:
[    0.962636] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[    0.962643] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=none,locks=none
[    0.962646] vgaarb: loaded
[    0.962647] vgaarb: bridge control possible 0000:01:00.0
[    0.962648] vgaarb: bridge control possible 0000:00:02.0
[    1.470217] Linux agpgart interface v0.103
[    1.470269] agpgart-intel 0000:00:00.0: Intel Sandybridge Chipset
[    1.470374] agpgart-intel 0000:00:00.0: detected gtt size: 2097152K total, 262144K mappable
[    1.471751] agpgart-intel 0000:00:00.0: detected 32768K stolen memory
[    1.471906] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xc0000000
[    1.472008] [drm] Initialized drm 1.1.0 20060810
[    1.472063] i915 0000:00:02.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    1.472067] i915 0000:00:02.0: setting latency timer to 64
[    1.519076] mtrr: no more MTRRs available
[    1.519077] [drm] MTRR allocation failed.  Graphics performance may suffer.
[    1.519729] i915 0000:00:02.0: irq 41 for MSI/MSI-X
[    1.519733] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[    1.519734] [drm] Driver supports precise vblank timestamp query.
[    1.519760] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=none:owns=io+mem
[    1.519762] vgaarb: transferring owner from PCI:0000:00:02.0 to PCI:0000:01:00.0
[    1.922510] fbcon: inteldrmfb (fb0) is primary device
[    2.041708] Refined TSC clocksource calibration: 2192.876 MHz.
[    2.041715] Switching to clocksource tsc
[    2.296103] Console: switching to colour frame buffer device 200x56
[    2.299242] fb0: inteldrmfb frame buffer device
[    2.299243] drm: registered panic notifier
[    2.309022] acpi device:32: registered as cooling_device8
[    2.309199] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A08:00/LNXVIDEO:00/input/input2
[    2.309205] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    2.309238] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[    2.309290] nouveau 0000:01:00.0: enabling device (0006 -> 0007)
[    2.309296] nouveau 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    2.309300] nouveau 0000:01:00.0: setting latency timer to 64
[    2.310866] [drm] nouveau 0000:01:00.0: Detected an NVc0 generation card (0x0cf680a1)
[    2.321840] [drm] nouveau 0000:01:00.0: Attempting to load BIOS image from PRAMIN
[    2.331565] [drm] nouveau 0000:01:00.0: ... BIOS signature not found
[    2.331567] [drm] nouveau 0000:01:00.0: Attempting to load BIOS image from PROM
[    2.331575] [drm] nouveau 0000:01:00.0: ... BIOS signature not found
[    2.331576] [drm] nouveau 0000:01:00.0: Attempting to load BIOS image from PCIROM
[    2.341386] nouveau 0000:01:00.0: Invalid ROM contents
[    2.341455] [drm] nouveau 0000:01:00.0: ... BIOS signature not found
[    2.341457] [drm] nouveau 0000:01:00.0: Attempting to load BIOS image from ACPI
[    2.341460] [drm] nouveau 0000:01:00.0: ... BIOS signature not found
[    2.341462] [drm] nouveau 0000:01:00.0: No valid BIOS image found
[    2.347607] nouveau 0000:01:00.0: PCI INT A disabled
Der original nVidia-Treiber gibt ähnliche Meldungen von sich. Zudem erhalte ich, wenn ich die Klappe schließe und wieder öffne ACPI-Fehlermeldungen, die auf die PCI-Express-Graphik hindeuten. Bios-Update half nichts.
Vielleicht kennt jemand dieses Problem.
Gruß,
Ayron
das heißt auch bei Spielen geht sie nicht an oder? Was meinst du mit "Klappe wieder schließt und öffnet".
Hast du schonmal Alien autopsy versucht, obwohl da kommt wahrscheinlich das gleiche raus.
Ich würde sagen das ist ein Hardware Fehler und ich fürchte du musst den Support kontaktieren.
Mit Klappe schließen mein ich das Notebook zu- und wieder aufklappen. Unter Windows bleibt der Bildschrim dunkel und unter Linux kommt das Bild wieder, aber der Kernel beginnt sofort eifrig ACPI-Fehlermeldungen zu produzieren, dass die Log-Files innerhalb kurzer Zeit schon zig GB groß sind.
Ich werd morgen mal den Support anrufen. Hoffentlich können die weiterhelfen.
Edit: Hab heut angerufen. Bekomm ein neues Mainboard. Hoffentlich geht das dann.
Nachtrag:
Gestern hat der Techniker nochmal bei mir angerufen. Das Bios-Update und eine gepatchte inf-Datei haben nun dazu geführt, dass der nVidia-Chip zum Leben erwachte.
Auch die ACPI-Fehlermeldungen unter Linux sind nun weg. Jetzt klappt alles soweit recht gut.
Bearbeitet von Ayron
