Area-51 R2 commandcenter läßt sich nicht installieren....
ich bekomme keine ErrMld nur das folgende Protokoll. Weiß jemand warum es nicht geht? hab alle Updates von Win7 drauf.
[04/10/15 12:57:05] Update Package Execution Started
[04/10/15 12:57:05] Original command line: "F:\Alienware\Driver\7 CommandCenter\Alienware Command Center 4.0 for Desktops Application_JD5K1_WN_4.0.51.0_A02.EXE"
[04/10/15 12:57:05] DUP Framework EXE Version: 3.1.2.1
[04/10/15 12:57:05] DUP Release: JD5K1A02
[04/10/15 12:57:05] Intializing framework...
[04/10/15 12:57:05] logo.png
[04/10/15 12:57:08] User Command: attended
[04/10/15 12:57:08] DUP Capabilities Value: 35651583 (0x21FFFFF)
[04/10/15 12:57:08] DUP Vendor Software Version: 4.0.51.0
[04/10/15 12:57:08] Local System/Model Compatible with this Package? Yes
[04/10/15 12:57:08] Local System OS Version: 6.1.1.0
[04/10/15 12:57:08] OS Compatible with this Package? Yes
[04/10/15 12:57:08] Local System OS Language: DE
[04/10/15 12:57:08] Language Compatible with this Package? Unknown
[04/10/15 12:57:09] Identified Behavior : attended
[04/10/15 12:57:09] Temporary payload log file name: C:\ProgramData\dell\drivers\Alienware Command Center 4.0 for Desktops Application_JD5K1_WN_4.0.51.0_A02\DUP902D.tmp
[04/10/15 12:57:09] Translated Command Line : setup.exe /Verbose""C:\ProgramData\dell\drivers\Alienware Command Center 4.0 for Desktops Application_JD5K1_WN_4.0.51.0_A02\DUP902D.tmp""
[04/10/15 12:57:09] Path : C:\ProgramData\dell\drivers\Alienware Command Center 4.0 for Desktops Application_JD5K1_WN_4.0.51.0_A02
[04/10/15 12:57:19] Append Vendor Software Log: C:\ProgramData\dell\drivers\Alienware Command Center 4.0 for Desktops Application_JD5K1_WN_4.0.51.0_A02\DUP902D.tmp
[04/10/15 12:57:19]
--- Start of Vendor Software Log ---
[04/10/15 12:57:19]
--- End of Vendor Software Log ---
[04/10/15 12:57:19] Vendor Software Return Code: 1203
[04/10/15 12:57:19] logo.png
[04/10/15 12:57:19] Name of Exit Code: UNKNOWN_OPTION
[04/10/15 12:57:19] Exit Code set to: 11 (0xB)
[04/10/15 12:57:19] Result: FAILURE
[04/10/15 12:57:27] Open file: C:\ProgramData\Dell\UpdatePackage\Log\Alienware Command Center 4.0 for Desktops Application_JD5K1_WN_4.0.51.0_A02.txt
[04/10/15 12:58:06] User Command: attended
[04/10/15 12:58:06] DUP Capabilities Value: 35651583 (0x21FFFFF)
[04/10/15 12:58:06] DUP Vendor Software Version: 4.0.51.0
[04/10/15 12:58:06] Local System/Model Compatible with this Package? Yes
[04/10/15 12:58:06] Local System OS Version: 6.1.1.0
[04/10/15 12:58:06] OS Compatible with this Package? Yes
[04/10/15 12:58:06] Local System OS Language: DE
[04/10/15 12:58:06] Language Compatible with this Package? Unknown
[04/10/15 12:58:06] User Parameter: logfile
[04/10/15 12:58:06] User Parameter: logfile changed to: C:\ProgramData\Dell\UpdatePackage\Log\Alienware Command Center 4.0 for Desktops Application_JD5K1_WN_4.0.51.0_A02.txt
[04/10/15 12:58:07] Identified Behavior : attended
[04/10/15 12:58:07] Temporary payload log file name: C:\ProgramData\dell\drivers\Alienware Command Center 4.0 for Desktops Application_JD5K1_WN_4.0.51.0_A02\DUP73C9.tmp
[04/10/15 12:58:07] Translated Command Line : setup.exe /Verbose""C:\ProgramData\dell\drivers\Alienware Command Center 4.0 for Desktops Application_JD5K1_WN_4.0.51.0_A02\DUP73C9.tmp""
[04/10/15 12:58:07] Path : C:\ProgramData\dell\drivers\Alienware Command Center 4.0 for Desktops Application_JD5K1_WN_4.0.51.0_A02
[04/10/15 12:58:18] Append Vendor Software Log: C:\ProgramData\dell\drivers\Alienware Command Center 4.0 for Desktops Application_JD5K1_WN_4.0.51.0_A02\DUP73C9.tmp
[04/10/15 12:58:18]
[04/10/15 12:58:18]
[04/10/15 12:58:18] Vendor Software Return Code: 1203
[04/10/15 12:58:18] logo.png
[04/10/15 12:58:18] Name of Exit Code: UNKNOWN_OPTION
[04/10/15 12:58:18] Exit Code set to: 11 (0xB)
[04/10/15 12:58:18] Result: FAILURE
[04/10/15 12:58:35] Open file: C:\ProgramData\Dell\UpdatePackage\Log\Alienware Command Center 4.0 for Desktops Application_JD5K1_WN_4.0.51.0_A02.txt
[04/10/15 12:59:09] Name of Exit Code: UNKNOWN_OPTION
[04/10/15 12:59:09] Execution terminated at date-time 04/10/15 12:59:09
[04/10/15 12:59:09] ######
਍਍[04/10/15 13:29:02] Update Package Execution Started
[04/10/15 13:29:02] Original command line: "F:\Alienware\Driver\7 CommandCenter\Alienware Command Center 4.0 for Desktops Application_JD5K1_WN_4.0.51.0_A02.EXE"
[04/10/15 13:29:02] DUP Framework EXE Version: 3.1.2.1
[04/10/15 13:29:02] DUP Release: JD5K1A02
[04/10/15 13:29:02] Intializing framework...
[04/10/15 13:29:02] logo.png
[04/10/15 13:29:05] User Command: attended
[04/10/15 13:29:05] DUP Capabilities Value: 35651583 (0x21FFFFF)
[04/10/15 13:29:05] DUP Vendor Software Version: 4.0.51.0
[04/10/15 13:29:05] Local System/Model Compatible with this Package? Yes
[04/10/15 13:29:05] Local System OS Version: 6.1.1.0
[04/10/15 13:29:05] OS Compatible with this Package? Yes
[04/10/15 13:29:05] Local System OS Language: DE
[04/10/15 13:29:05] Language Compatible with this Package? Unknown
[04/10/15 13:29:06] Identified Behavior : attended
[04/10/15 13:29:06] Temporary payload log file name: C:\ProgramData\dell\drivers\Alienware Command Center 4.0 for Desktops Application_JD5K1_WN_4.0.51.0_A02\DUP6038.tmp
[04/10/15 13:29:06] Translated Command Line : setup.exe /Verbose""C:\ProgramData\dell\drivers\Alienware Command Center 4.0 for Desktops Application_JD5K1_WN_4.0.51.0_A02\DUP6038.tmp""
[04/10/15 13:29:06] Path : C:\ProgramData\dell\drivers\Alienware Command Center 4.0 for Desktops Application_JD5K1_WN_4.0.51.0_A02
[04/10/15 13:29:13] Append Vendor Software Log: C:\ProgramData\dell\drivers\Alienware Command Center 4.0 for Desktops Application_JD5K1_WN_4.0.51.0_A02\DUP6038.tmp
[04/10/15 13:29:13]
[04/10/15 13:29:13]
[04/10/15 13:29:13] Vendor Software Return Code: 1203
[04/10/15 13:29:13] logo.png
[04/10/15 13:29:13] Name of Exit Code: UNKNOWN_OPTION
[04/10/15 13:29:13] Exit Code set to: 11 (0xB)
[04/10/15 13:29:13] Result: FAILURE
[04/10/15 13:29:23] Open file: C:\ProgramData\Dell\UpdatePackage\Log\Alienware Command Center 4.0 for Desktops Application_JD5K1_WN_4.0.51.0_A02.txt
