M17x R3 7970m
AlienOnFire
Are you trying to install the 7970m for the first time in that notebook or did the card work already?
What BIOS version do you use? Probably an unlocked one is recommened to use inoffical hardware.
Regardless, you should proof the correct fitting of the card and/or load the BIOS optimal defaults to reset all IRQ's.
